-   -   1998 Sat SL2 (https://www.saturnforum.com/forum/general-tech-help-13/1998-sat-sl2-1646/)
Layla801 Jan 23, 2008 03:59 PM
Hi I am new here and I am looking for info on on Saturn I have at the shop...its a 1998 Sat. SL2, Auto 1.9L DOCH It needs a transmission replaced, and I found one for $450 and came across a TSB stating that the soon to be replacement transmission(the used unit) has to have the VIN# some how interchange with the the vehicle's VIN # or else it will not work. I already tried to call the Dealer here locally and they are nothing but kids who don't really know nothing. The service won't help unless I take it there and have them work on it, no suprise there. Does anyone or has anyone heard of this??
Edited by: sw2cam
Low Saturn Jan 23, 2008 07:06 PM
You need to find a 1995-2001 MP7 automatic transmission. Gear ratios and electronics of the valvebody changed throughout the years. Thats why they want to verify your VIN. $450 is a lot of money for a used transmission. What exactly is wrong with yours?
Layla801 Jan 24, 2008 09:50 AM
It won't shift out of 2nd gear and has set transmission codes for the check engine light. When the light is reset it works for about a few minutes then goes back to acting up again.
original007 Jan 24, 2008 05:27 PM
What codes are set sounds like you have a stuck/inop actuator in the valve body
