Alpha Centauri |
04-27-2015 01:09 AM |
Hi Dispatch8, have you had any luck yet? I'm rebuilding a 1993 SC1, and I have gotten almost everything I've needed so far, including a manual window regulator for the driver's side at Car-Part.com--Used Auto Parts Market. It's a listing of salvage yards all over the USA, and it gives address and phone numbers so you can call them directly with any questions, including shipping costs. When you go to the sight, you list all your information about your vehicle, and what you are looking for. Then up pops a listing of salvage yards that have that part in stock, and the price, so it's easy to compare prices. Make sure you check the right age group / generation because they will list 91 to 2001. Some of those parts will interchange, regulators will not interchange between generations, or 2 to 4 doors. Make sure you call the Yard you're considering before ordering, because some of the vendors don't update their database very often. The regulators come out from the outside of the door. There is a video on u-tube that shows how easy it is to remove the outer door skin by removing the torx head bolts around the inside door panel. You will also need to remove the mirror, and outside door handle and weather strip at the top of the door skin. The handle removal is also on u-tube. I haven't started on mine yet, still waiting on shipment of the part. Best of luck on your project.
