-   -   04 vue headlight (https://www.saturnforum.com/forum/general-tech-help-13/04-vue-headlight-339/)
iuballer016 Mar 1, 2006 03:39 PM
i bought some new headlight bulbs for my 04 vue and i cannot figure out how to remove the headlight. it is impossible to access the bulb without removing the headlight, and after i removed the 2 screws that appear to hold the headlight in place, something else is still holding the headlight case
Collins Mar 1, 2006 03:55 PM
if you pop the hood you should be able to reach in behind and turn the bulb and socket to the left or right and pull it out. there might be a small clip you have to push in before you turn it. not sure. but for mostthis is how its done.
