-   Engine & Internal (https://www.saturnforum.com/forum/engine-internal-16/)
-   -   Tensioner Problem (https://www.saturnforum.com/forum/engine-internal-16/tensiner-problem-2360/)
awilliams7 Aug 12, 2008 11:02 PM
I have a ''99 Saturn SC2 and recently it was making a squeaking noise which I found out was the belt, I replaced the belt because it was really loose, now I think the tensioner is the problem and I don''t know if it is broken and need a new one or it just needs to be tightened. Does anyone know the best way to fix this or had a similar problem?
Low Saturn Aug 13, 2008 09:21 AM
You cant tighten the tensioner. If the spring inside is broken or worn, replace the tensioner.
