temperature idiot light flashing
Old Jan 27, 2006 | 01:01 AM
donclaypool's Avatar
I just flushed the coolant and replaced the thermostat in 97 sc1. It was stuck open. Now the Temp/Coolant Level idiot light will not stop flashing. The T-stat is working, and the fan cycles o.k., temp indication is o.k. Isthe idiot light controlled by anothersensor somewhere? My repair manual has disappeared and the wife is driving me crazy. HELP!
dON
Old Jan 31, 2006 | 10:16 PM
O.k., I figured it out with some help from a previous post. I needed to replace the coolant temp sensor, located on the drivers side of the head,AND dismantle and clean the connection. The connection must be pinched to remove from the sensor or you will tear the wires out like I did! Duh. Check out the sensorat the front of the air intake tubeto see the same type of connection.
Moorecd
Aug 7, 2010 11:23 AM
jonnyghost
Jan 26, 2010 08:26 AM
coconutprincess
Mar 22, 2007 10:52 PM
Tmoney
Dec 2, 2006 02:34 AM
dec29p
Jun 18, 2006 06:37 PM
