-   Engine & Internal (https://www.saturnforum.com/forum/engine-internal-16/)
-   -   Short Throw Shifter? (https://www.saturnforum.com/forum/engine-internal-16/short-throw-shifter-6382/)
'98 Saturn SC2 Dec 13, 2011 04:48 PM
I was thinking about short shifting my car but I don't know how to do it exactly. If anyone can help by giving some advice or by making one for me lol.
Octavious Dec 13, 2011 11:26 PM
Im in the process of doing this, im just cutting the shifter. I did it on another shifter i had from the junk-yard but I cant put it in since the boot clips are broken and it would look fugly.
Maybe get a junkyard shifter as well so if you mess up youll still have a shifter
Ill let you know how well it works, although I wont get to do it for abit
'98 Saturn SC2 Dec 14, 2011 01:39 PM
Aight cool, I'll check it out. I might go to the junkyard today. I might get a couple because knowing me I will screw it up lol. Let me know how it works out for you.
loudestsaturnever Dec 15, 2011 08:27 PM
i did it to mine. i just cut it in half, and shortened up the boot a bit. looks and works great
Octavious Dec 15, 2011 10:21 PM
how did you shorten the boot? did you take it off the top or bottom?
loudestsaturnever Dec 16, 2011 09:34 AM
took it off the top. and i know this dont sound manly, but after i cut the top i just i sewed it back together
08astraxr Dec 18, 2011 10:11 PM
Just cutting the shaft of the shifter will not make a ( short throw shifter). All that will do is change the hight of your shift knob, and with less leverage it might even be harder to shift. Looking at my Astra being front wheel drive I'm not sure how they would make a true short throw for it. Id like to have one for my car.
'98 Saturn SC2 Dec 18, 2011 10:42 PM
I'm not trying to change the height that much, I really want a short throw shifter.
08astraxr Dec 19, 2011 09:50 AM
Ok well by cutting your shifter that will not make a short throw shifter. All it will do is lower your shift knob. I'm new to saturns but by no means new to cars. So I'm assuming the concept of a short throw shifter will be the same for most cars. For a "short throw shifter" what they actually do is lengthen the "throw part" of the shifter. Therefor making the actual lenght that the shifter knob travels shorter. I'll try and do some research to try and explain myself a little better and get back to you.
Octavious Dec 19, 2011 01:28 PM
I know how it works, however the top half of the shifter on the s-series is ridiculously long in my opinion, so cutting it will help either way, even if it doesn't make shifts shorter it makes them less sloppy since there is alot of play in these shifters..
Unfortunately they dont exist anymore for these cars (and apperently they really never did), or your very, very good at searching, or you make it yourself.
Im doing some digging and looking for instructions.
http://www.saturnspot.com/showthread.php?t=25474
These guys claim to make a short throw, however in the picture it looks like a stock shifter.
I've emailed them to see if I can get some more pictures and information.
http://www.villagemachiningservice.com/page04.html
