Greetings to all I am buying my first Saturn. It is a ''''''''99 with the 1.9 DOHC and a manual trans. I found one answer to the question "can you lift the motor out of the engine bay" so that is a plus already! The motor has a knock in it and I suspect a rod. I am going to pull the motor and to a through rebuild. I am a vetern gear head and have access to all the equipment and/or the people to do quality work. Is there a "master engine kit" available that is good quality. I saw one on Ebay, but it looks a little cheap. i will replace what ever is needed and then some just to be safe. This car will be my commutor car and I rather rebuild and have confidance that the motor is good. The rebuild will also include new sensors and a clutch, Any other advice? What is the best manual to get for reference?Edited by: LASER3KW |
i would start by dropping the oil pan to see if you in fact have a problem with the internals of the engine, but thats just me. You can check your bearing tolerances from there and also drop the crank if you needed to. Also i would check the timing. It may be that its off and your valves are knocking against the pistons. Have you tried a compression test at all?
There are no master engine kits. I get parts from different sources when I rebuild engines. You get better parts that way too.
As for manuals, the Factory Service manuals are the best. Anything else is just fancy toilet paper with writing on it. |
Thanks for the input guys. The noise comes from the left front of the motor near the bottom. I am preparing for the worse. I will open it up and determine what is needed. But the car lot is sneaking the price up. It started out at less than $1500, then it was $1550, now it''''s $1650 PLUS tax title and doc. HA! I think not. I can buy a running ''''99 for $200 and not do anything to it! We''''ll see - I am going to give it one more shot tonight. I did find one source for master kit. It''''s Ron''''s Performance machine, But it'''' $950 for everything except cam and crank. Good parts, Seal Pro piston and rings, Federal mogal ect. PS why can''t I responde to this post from home but I can from work?Edited by: LASER3KW |
Laser,
Just saw your post. If possible can you post pics of your old main and rod bearings and approx mileage on them? |
LASER3KW ... Simple answer - you logged on originally from work, but have not done so from home ... |
