I have a window problem. The power window on the passenger side will go up, but not down. The driver side works fine. I have isolated the problem to the switch. Do i replace the switch? If so, where do i find the best deal without going to the dealership. They had it for $120. Is there a way i can repair the switch? Any help would be appreciated.
Junkyard. |
It is possible to clean the contacts inside the switch. 99 times out of 100 this cures the problem with a faulty switch.
