< src="http://www.google-analytics.com/urchin.js" =text/> </> hey im new to saturns, ive worked on dodge, mitsu, and toyota since ive been a mechanic. now i pulled a code form my saturn sayin sumthin wrong with camshaft position sensor. now thats fine and dandy, but i cant find a store that carries the part, most of the stores have even said that they dont have tha part listed. now my question is, does the part go by a differant name or are the parts store monkeys stupid, any info on this will be greatful. < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
P0341 NOT REALLY A CPS REPLACE THE 1/4 COIL
Saturns dont have a camshaft postion sensor because the ignition module uses capacitive pickup plates located under the 1/4 coil pack to determine the polarity sequence and voltage amplitude of the cylinder 1/4 secondary ignition. The PCM supplies 5 volts on the signal line and expects to see the cylinder #4 signal wire go low after every 14 crankshaft pulses (2 revolutions). This is used to determine the position of the camshaft. Also when referring to a CPS in a Saturn, its the Crankshaft Position Sensor.
And if your getting a P0341 its unlikely it needs a new 1/4 coil pack. Check for corrosion on the terminals at the coil, fouled spark plugs, bad wires or oil in the spark plug well #4. 99% of the time, its one of those four things. Edited by: Low Saturn |
Originally Posted by 97sc1
(Post 6868)
Welcome to the forum, please limit responses to your knowledge level. Your response is incorrect and misleading in this case.
This thread is also from 2008 so maybe you are a Bot. |
Banned.
If you're an actual person and want to join and not give vague incorrect answers to 17 yr old posts that have already been answered , create another account from a different IP address and make your username your email address first section backwards. |
| All times are GMT -5. The time now is 02:55 AM. |
