camshaft position sensor??
Old 01-01-2008, 07:00 PM
97sc1's Avatar
hey im new to saturns, ive worked on dodge, mitsu, and toyota since ive been a mechanic. now i pulled a code form my saturn sayin sumthin wrong with camshaft position sensor. now thats fine and dandy, but i cant find a store that carries the part, most of the stores have even said that they dont have tha part listed. now my question is, does the part go by a differant name or are the parts store monkeys stupid, any info on this will be greatful.
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old 01-05-2008, 03:17 PM
original007's Avatar
P0341 NOT REALLY A CPS REPLACE THE 1/4 COIL
Old 01-06-2008, 11:37 AM
Low Saturn's Avatar
Saturns dont have a camshaft postion sensor because the ignition module uses capacitive pickup plates located under the 1/4 coil pack to determine the polarity sequence and voltage amplitude of the cylinder 1/4 secondary ignition. The PCM supplies 5 volts on the signal line and expects to see the cylinder #4 signal wire go low after every 14 crankshaft pulses (2 revolutions). This is used to determine the position of the camshaft. Also when referring to a CPS in a Saturn, its the Crankshaft Position Sensor.
And if your getting a P0341 its unlikely it needs a new 1/4 coil pack. Check for corrosion on the terminals at the coil, fouled spark plugs, bad wires or oil in the spark plug well #4. 99% of the time, its one of those four things.
Edited by: Low Saturn
dabatman99
08-13-2023 07:16 AM
sep25
07-24-2011 10:56 AM
ChurchBuilder
07-20-2007 05:18 AM
Genocide
04-17-2006 02:15 AM
mpk4580
01-25-2006 08:09 AM
Quick Reply: camshaft position sensor??
