-   Engine & Internal (https://www.saturnforum.com/forum/engine-internal-16/)
-   -   auto trans question (https://www.saturnforum.com/forum/engine-internal-16/auto-trans-questin-317/)
tnsaturn Feb 11, 2006 09:42 PM
i have a 95 sl2 and im wondering what years are interchangable with it cause i need a new trans thanks.
ottjoe88 Feb 14, 2006 02:59 AM
if the transmission jerks or bang when put in reverse, then the reverse clutch needs to be tightened, if it bangs through all the geras or any beside reverse, then it needs a new control module. if either of these are the problem, then don't replace the transmission.
project92SC2 Apr 8, 2007 12:00 AM
92-98 are interchangeable... 91's have a different mounting style, but can still be used.
Go to http://www.differentracing.com/tech_...gearratio.html
Those are the different gear ratios used. Check them out.
