Hey guys i need some help im stumped, i got a 92 saturn that will run on a full charged battier but as soon as the battiers dead the car stails and is dead, i replaced tha battier and i tried two used altanators, plus i but my first altantor to a volt meter and its charging some but not enought... no one know what the heck is wrong with it HELP!!!! thanks corey |
i would say just check your grounds and all of your connection and fuses and most of the main electrical work
I agree... Something is draining your battery. Any after market sound system stuff? Check that. Bare wire from you battery post... check for that too.
Pull down your back-seat, and see if your trunk-light is stuck on... just a thought. It happens a lot. Check all the ground wires and cables under the hood. You have a closed circuit somewhere... find out where. Time for a multimeter. |
