05 Saturn Relay getting head gasket replaced
Old Feb 23, 2023 | 03:02 AM
chrissy0909's Avatar
Default 05 Saturn Relay getting head gasket replaced
Hi everyone. I was really hoping you guys could help me out. I have an 05 Saturn Relay 3.5l V6 engine. 2wd. My friend who is a mechanic is going to do the job for me but he cannot find his repair manual and so he cannot remember the exact order the bolts go in or the maximum torque allowed when putting them back in. If anyone knows this info I'd greatly appreciate it. Thank you so much.
Old Feb 23, 2023 | 06:47 PM
Ignore everything I said. I just found the actual information. I will post it shortly
Old Feb 23, 2023 | 06:59 PM
Per Wikipedia, your engine is the LX9 3.5L V6.
Wikipedia Saturn Relay
Cylinder head bolt specs are in the attached PDF along with every other LX9 torque spec you will ever need.
I will now look for the order of tightening as it is not included in the attached document
Tightening order
One bank
Other bank. Seems they should be identical and they are.
This order was from
https://www.justanswer.com/saturn/9lmnf-head-bolt-torque-torque-sequence-2006.html
For the torque directions, follow the PDF. It is a GM document
File Type: pdf
Saturn Relay
50
Sep 27, 2019 10:42 PM
Rubehayseed
Aug 27, 2013 09:51 PM
redturbo0
Mar 22, 2009 07:24 PM
gw165
Apr 9, 2008 08:58 PM
Mera
Sep 1, 2007 09:37 AM
