Steering Wheel Shake 65+mph
Old Mar 18, 2007 | 12:17 AM
Secretagent0057's Avatar
I am having a bit of trouble with my L100 at speeds of over 65mph. Does anyone else have this problem, and if so what have you done to correct it?
Old Mar 18, 2007 | 10:22 PM
S-Turn's Avatar
check the alignment. probably one too many curb collisions. also check the tires to see if they are wearing evenly, and that they don't have any bulges in them. could be many things, so you can also try taking off the front tires and looking at the tie rod ends, a-arms, etc.to give us a better chance at helping you out.
-S-Turn-
Old Mar 19, 2007 | 08:03 PM
Thanks S-turn. I will put her on a rack and take a look. I'll let you know what I come up with.
Old Mar 30, 2007 | 07:42 PM
S-turn,
I had new tires and rims installed. The steering wheel shake is barely noticable. I also had the tie-rods checked and they look good. The sway bars were a bit loose so that may be causing the the minor shake. I'll let you know if this does the trick. Thank you for all of your help.
Old Mar 30, 2007 | 09:07 PM
GarrenNatas's Avatar
I have a buddy that had this problem in his truck... So to fix it, he planned on just tightening the bolts the hold the steering wheel to the column... He ended up with an airbag in the face... LOL
Old Jun 19, 2007 | 12:29 PM
lamont4689's Avatar
have the wheels spin balanced---
all the shake will disappear
Old Jun 19, 2007 | 03:51 PM
Balance balance balance all four tires and wheels. If the tires are bad if the wheels are bad replace them.
Old Jun 9, 2008 | 04:28 PM
mikederocher's Avatar
It''s the tire balance.
gambils2
Jan 16, 2015 10:01 AM
Ramos617
Oct 31, 2010 09:17 AM
tonygarcia1990
Jan 19, 2010 12:01 PM
tonygarcia1990
Jan 7, 2010 09:08 PM
geramos
Jul 20, 2007 03:56 PM
