98 sl2 sunroof won't open
Old 03-25-2013, 09:55 PM
Lcgreene2's Avatar
Default 98 sl2 sunroof won't open
When I press the button it makes the noise like its gonna open but doesn't does anyone no what this is
Old 03-25-2013, 10:10 PM
Sunroof Module
You can search Saturn Sunroof Module on the internet and you should come up with what you need.
No need to double post, thanks.
Old 03-25-2013, 10:35 PM
Lcgreene2's Avatar
Yeah sorry about that double it was an accident using and IPad that acts weird sometimes
Old 03-26-2013, 07:29 PM
krazy Dan's Avatar
Prob what sw2cam said. Im not sure about the SR module. But I can tell you in my last 97 that I had, it had a sunroof. SR motor made the noise but it wouldn't open. I took it completely apart and and found it to be both the plastic tabs (part of the rail assembly that slides the SR) were completely broken. So the rails were moving but the SR was not. May want to pull it out and check. Pretty easy task if you have basic tools.
Old 03-26-2013, 11:09 PM
yea those plastic tabs all pretty much break eventually.
Old 03-28-2013, 07:02 PM
Lcgreene2's Avatar
Where can I get those clips if that's it.
Old 03-29-2013, 12:50 PM
unc? do you have a source?
Old 03-30-2013, 03:40 AM
krazy Dan's Avatar
Well I'd definately pull it apart first to be sure. but if it is the case your best bet senario is probably a "you pull it" type local junk yard. We have LKQs around here. You should have something similar. You could check with a GM dealer but I dought they will have them anymore.
tikidude
08-30-2014 05:04 PM
SL2
12-23-2012 11:35 AM
WhichWayToday
02-16-2008 01:07 PM
ThaBean
05-02-2007 12:32 PM
TiaAna8
05-01-2006 11:51 AM
Quick Reply: 98 sl2 sunroof won't open
