timing belt ?
Old Aug 18, 2006 | 12:07 AM
vetteguy's Avatar
Does my 94 SL-2 have a timing belt and if it does when should it be changed? 84500 miles
Old Aug 20, 2006 | 09:26 AM
Steel timing chain -- not a belt.
As long as you've kept your oil up, you should be ok for a while longer.
Typically it does not make sense to do the timing chain on an S car unless you're in there doing something else, except of course if it is becoming extremely </span>noisy and you fear it is gonna let loose.
I believe some of the older S cars had some design issues wherein an "insufficient" amount of oil was getting to the timing chain.
Probably good to 150-200K on a properly maintained S car engine.....
mklein
Jun 27, 2008 11:42 AM
Racemare
Jan 9, 2008 09:43 PM
90base
Sep 27, 2007 04:05 PM
shakr
Sep 6, 2007 11:35 PM
B3SL1
Aug 4, 2005 09:49 AM
