surging and high idle problem
Old Jun 16, 2006 | 02:20 AM
x86guru's Avatar
94 saturn sl2 140000 sat 2 years now running but had hesitation and fan didn't click on so replaced ect sensor and ran injector cleaner now runs great except idles really high now. It was at normal 700rpm before and now its at 1200-1400rpm and surges up and down between 500 and 1400rpm for a bit until it finally settles at 1200rpm. Any ideas? Should I replace the ect again or what? I took about 5 different applications of the injecter cleaner could that have caused this? Is there another sensor that needs to be replaced? Thank you very much for your consideration and suggestions!! Sam x86guru@hotmail.com
Old Jun 16, 2006 | 05:43 AM
Did you replace ECTS with a brass tipped one? Must use the brass tipped replacement.
Also, if ECTS connector is even slightly corroded, the signal to the PCM can get hosed. Hosed coolant temp sensor signal to PCM often leads to high idle (and other unwanted performance related effects)....
Recommend replacement of brass tipped ECTS and connector with Saturn parts. Connector is Saturn-only, quite pricey, but prone to corrosion, especially if coolant has seeped into the connector from failure of the original ECTS.
Also -- check for vacuum leak around intake manifold and around the throttle body.
Please post resolution
Old Jun 16, 2006 | 07:09 AM
x86guru's Avatar
ok thanks... I have the brass tipped one but I think I remember the connector being corroded.... Thanks again and I'll send back info after replacement ! SamEdited by: x86guru
Old Jun 17, 2006 | 04:24 PM
x86guru's Avatar
[QUOTE=x86guru]You guys are the best!!! I went with the Saturn ect sensor and new connector and it runs like new now! I am extremely impressed with your quick, accurate response!!! Incidently, Saturn dropped the price of the connector due to the extremely high failure rate with these... It came out to $35 for both the sensor and connector! Thanks again you are a rock star! Sam
cloudsplitter8
Aug 24, 2012 07:47 PM
l200saturn
Jun 15, 2012 09:54 AM
dcarste
Feb 15, 2009 01:59 PM
Mera
May 18, 2008 08:01 PM
bryant
Feb 27, 2006 12:49 AM
