transmission
Old Apr 18, 2006 | 02:04 PM
2DOLLAR's Avatar
I have a 94 sl dohc with auto tran. my problem is it will not pull in reverse . Ive been told that it is the valve body .if so what is involved in changing it? and where is the best place to find one ?can some one please help me with some info or maybe some pics. ?thanks for any help!!!!!
Old Apr 19, 2006 | 07:51 PM
VALVE BODY MAYBE, BUT FIRST OFF I WOULD TRY TO JUST TIGHTEN THE REVERSE GEAR CLUTCH. THEY ARE KNOWN FOR GETTING LOOSE AND CAUSING THE SYMTOM YOU MENTIONED. TAKE IT TO A SATURN DEALERSHIP AND HAVE THEM TIGHTEN THE NUT.
Old Apr 20, 2006 | 01:48 AM
2DOLLAR's Avatar
do you know where this nut is located ? can I not tighten it myself ? thank you for your help.
Old Apr 24, 2006 | 04:45 PM
jack up the left side of the car as high as it will go,put on jack stands, put jack under transmission, lossen driver side of engine cradle and take top shock bolts off, remove inner fender and you will see the side of the tyransmission. remove the side of the transmission. the part you will see is the transmission clutch. grind down a 15\16 deep socket until it will go int the whole. tighten it back up by using an impact on it and impact the hell out of it. now put it back together
Old May 4, 2006 | 01:11 PM
2DOLLAR's Avatar
HEY OTTJOE CAN YOU PLEASE SEND ME THE PICS. THAT YOU HAVE OF THE BOLT OR ANYTHING ELSE THAT CAN HELP ME THANKS ALOT FOR ALL THE FAST INFO
cwalker2@charter.netEdited by: 2DOLLAR
Old May 4, 2006 | 05:05 PM
sorry, my camera is broken, so i am trying to borrow a digital from my friend.
Old May 5, 2006 | 10:58 PM
Red94's Avatar
Thanks ottjoe88 for the lead for the repair on the reverse problem. Was able to figure it out with the help from a local shop.thanks again.
gpsman4
Jan 19, 2009 04:01 PM
jizake1jz
Aug 3, 2008 09:46 PM
denvermoe
Feb 15, 2008 02:43 PM
ottjoe88
Jul 13, 2005 07:38 PM
ZigZag
Mar 29, 2005 01:06 PM
