Stiff Steering
Old Mar 31, 2006 | 09:11 PM
dgi007's Avatar
just recently my streeing has become stiff.... so much that when i make a turn it wont correct its self.... i can sit in a parking lot just spining in circles until i froce the steering back..... anyone have any suggestiona bout what it might be ! |?
Old Apr 2, 2006 | 05:20 AM
euroc's Avatar
Possibly a power steering pump. Have you had any problems with losing fluid? If so, it could be a leak in a seal in your rack and pinion. Can you hear your pump when you try to turn it? Its one of those two things. Either the pump, or the rack. If your not leaking any clear fluid around your front axle, then I would lean to the pump. Let us know what you find out.
Old Apr 3, 2006 | 01:38 AM
euroc is correct, unless you at some point disconected the powersteering pump or ran it dry, then good luck purging the system, it is a pain in the rear
Old Apr 13, 2006 | 03:56 AM
euroc's Avatar
Thats true ott... air in the system could cause that too.
dandyisme
Jun 15, 2025 08:41 AM
JEKoenig0524
Feb 22, 2015 06:43 PM
saturne20
Aug 1, 2008 10:14 AM
lynn
Saturn L300
Sep 12, 2006 02:10 PM
phreak3739
Dec 3, 2005 01:44 AM
