I have a ’99 SL that misses on accelerati
Old Mar 10, 2006 | 10:44 PM
nuwt's Avatar
ok, I have replaced plugs and checked fuel pressure. it is at 47
pounds. I sprayed carb cleaner and checked for vacumn leaks all around
including intake. I have a fresh tank of gas with seaform additive and
it still missing/jerking. It is gettting worse tho, idles fine, runs
fine, just acts up on acceleration and worse under 2000 rpm's. it doesnt jerk or miss when it is floored. I pulled each wire
off and there was a noticeable difference in the rpms each time.
any other ideas?
Old Mar 15, 2006 | 11:11 PM
rchinny's Avatar
i am not a mechanic but i had a similar problem and it was the fuel injector....has any warning lights come on..ex check engine
Old Mar 16, 2006 | 03:30 PM
coil pack is bad
Old Mar 16, 2006 | 06:34 PM
nuwt's Avatar
Well, It was bad plugs. 2 of the 4 i bought was bad, So after replacing plugs again It runs smooth and fine!
Blue
May 8, 2016 08:43 AM
jmc8338
Sep 20, 2011 04:09 PM
taylor
Mar 8, 2008 08:20 PM
delorean004
Feb 28, 2008 11:40 PM
sl1driver
Jan 9, 2008 09:16 PM
