Search
Reply
Old 11-25-2008, 11:15 AM
redwolf4k redwolf4k is offline
Hi everyone. I am brand new to the forum.
Our 2002 SL2 is cranking, but not starting up.Battery is good, fuelpump good, but no spark. After testing the coil for #1 and #4, I found no spark, and purchased a new Crankshaft position sensor.
My wife needs the car to get to work. It has been raining all day today, and is supposed to rain the next two days straight here.
Bad luck...
I really need to get this car back on the road asap. Can I do this job from the top down? (under the hood as oppose to crawling under the car in the rain?)
I saw some videos that show the sensor right above the starter, so I figured I could see the sensor from above, but I can''t locate it.
Any tips? Any help would be greatly appreciated!
Thanks,
Rob
Old 11-26-2008, 03:19 AM
derf derf is offline
Gotta do from beneath. You''ll see it when you get under the car.
Put a piece of cardboard on the ground and you shouldn''t get too soaked. Or push it into a friendly neighbor''s garage to stay dry.
Old 11-26-2008, 03:39 PM
Igot manly about it and did it.
Was able to switch it out for a new one, but the vehicle still will not start.
it cranks and cranks....
it seems to be getting fuel, battery is turning the starter at normal speed, it gets spark at the coils for sure. It cant be the plug wires.
80k miles...
My wife now mentioned to me for the first time that the car has been really rough the first minute or two of startup. Like "vibrating". I always maintained oil level, and all other fluids. I don''t know what could have happened. Timing chain broke? i wish I knew more about cars!
I am gonna wind up getting it towed to a shop. I am out of ideas.Edited by: redwolf4k
Old 11-27-2008, 03:07 PM
Low Saturn Low Saturn is offline
You may have to take it to the dealer to do a crank relear procedure since you swapped out the sensor.
__________________
Mike
1991 Turbo SL2
11.809 @ 116.488 mph
www.differentracing.com
1995 2.0L Saturn SL2m
1993 SW2 - SOHC to DOHC swap
2001 Chevrolet Suburban LS
www.cardomain.com/id/lowsaturn
Reply
Tags
1995, 2005, 2006, cps, location, saturn, sensor, series
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Auto Parts
- Exhaust
- Bike Carriers
- Car Vacuums
- Hidden Hitch
- Hitch Covers
- Dash Kits
