fuses...Why?!?
Old Jul 8, 2008 | 09:15 PM
Touchless's Avatar
A few weeks ago i had problems over heating. So I checked the coolant. It was fine. I checked the fuses and replaced one. It was for the cooler fan #2. It is a 30A fuse. The car no longer over heated..wrong. I also changed my radiator fluid. But the fuse has blown again and i do not know why. Any help so as i don''t have to keep replacing it would be of great appreciation.
Touchless
Old Jul 9, 2008 | 08:14 AM
95jive's Avatar
wires touching or fan drawing too many amps? Happens when a fan is
going bad on any application.Edited by: 95jive
Old Jul 10, 2008 | 08:45 PM
Fuses blow because something is shorting out or drawing more amps then the fuse rating.
Old Jul 12, 2008 | 04:50 PM
I have found that if the bearing in the fan fails, the current to run the fan goes way way up ultimately blowing a fuse. Perhaps the fan is defective and needs to be replaced
RedSL2
Oct 8, 2009 08:53 PM
Herbwoman39
May 15, 2007 09:30 PM
henrylford
Audio/Visual Electronics
Apr 2, 2006 05:12 AM
henrylford
Jun 13, 2005 03:06 PM
trackwingsmsm
Apr 5, 2005 03:04 AM
