Reverse gear and transmission problem
Old Nov 7, 2005 | 07:53 PM
ozer's Avatar
Hi
I have 1992 Saturn SL-2. Car runs and drive fine. B Ut when I try to reverse, it has hard time to engage. It takes about 5 second to engage it. When it is engage it is really harsh. Car, shakes, make a loud noise and engage it. If I touch the gas pedal, it engage quickly but harsher. And most of the time, car stalls.
Someone told me that it may be the clutch in tranny or valve body. Anyone had similar problems or any idea.
thanks
ozer
Old Nov 8, 2005 | 01:12 AM
automatic or manuel? If automatic the bolt that holds the reverse planetary needs to be tightened. I will send you a picture if you want
Old Nov 8, 2005 | 03:38 PM
it seems like an automatic to me...
Old Nov 8, 2005 | 07:22 PM
ozer's Avatar
it Is AT. Yes I will need the picture. thanks
ozer@u.arizona.edu
Old Nov 9, 2005 | 08:33 PM
Tarl's Avatar
Could I get a copy of the picture also, I'm having the same problem
Old Nov 9, 2005 | 09:13 PM
dannyy72's Avatar
i wouldn't mind getting the picture as well, thanks a million.
dannyy72@hotmail.com
Old Nov 30, 2005 | 05:06 PM
i will get them to you asap. You will need access to a 1/2 in. drive air impact, a set of jack stands, a good set of sockets, a floor jack and a cheap 15/16 1/2 in drive deep socket that needs to be ground down
Old May 3, 2006 | 08:51 PM
Red94's Avatar
Hello OTTJOE88
I am having reverse troubles as well. Could you send me your photos and any info that may help me with this problem?I appreciate the help!
Thanks
Old May 4, 2006 | 01:03 PM
2DOLLAR's Avatar
PLEASE SEND ME PICS ALSO I HAVE ALREADY CHANGED THE VALVE BODY AND IT STILL WILL NOT PULL IN REV.THANK YOU FOR ANY HELP YOU CAN SEND MY WAY cwalker2@charter.net thanks agian!!!!!!!!!!!!!
AConsciousEarth
Apr 30, 2013 09:20 AM
jizake1jz
Aug 3, 2008 09:46 PM
jeffwallner
Aug 3, 2008 07:07 PM
gomoose
May 4, 2006 01:48 AM
rtrimarc
May 1, 2006 12:45 PM
