piston rings and head gasket
Old Jan 20, 2005 | 07:34 AM
jonni 95 SL2's Avatar
can i pull the pistons threw the head by dropping the oil pan or do i really have to pull the moter out? open for ideas
Old Feb 18, 2005 | 06:10 PM
ReydraX5's Avatar
You dont have to pull the motor out, but it would make it much easier just having it out and not having to lend on to the front of your car. You can take the head off and and the oil pan. Loose the Pistons and pull them from the top of the block and make sure you bore the piston holes and get new bearings.
Old Feb 18, 2005 | 10:24 PM
i sold the car the thing is you cant u must pull the motor. the timing chain cover is in ur way and so is the crank pully you also have the flywheel. there is 5/18 bolts you cant get to. thanks for the info though
Old Mar 17, 2005 | 07:57 PM
quantumzL69's Avatar
I would figure an ASE certified "Master mechanic" would know a simple question like that. Or at least someone who owns 3 shops and builds 11.1 second Civics and 7 second T/A's.
Old Mar 18, 2005 | 12:18 AM
i did but there are always short cuts, and guess what there would have been but there was 3 flywheel fex plate bolts that wouldnt let me do that besides you need to pull the trans and the engine as a hole. BET YOU DIDNT KNOW THAT but hey ase people still ask questions and read books. any good tech could tell you that!
Old Mar 18, 2005 | 02:32 AM
Actually, I did know that.It's funny what you can learn from a Chiltons manual. But your not just an ASE certified mechanic. You a certified "Master" mechanic.
Old Mar 18, 2005 | 05:17 AM
GrdLockV6's Avatar
Yes, you should be able to pull the pistons through the head by removing the oil pan. Piece of cake, really [img]smileys/smiley1.gif[/img]
Best time for all of this would be during an oil change, you're down by the oil pan anyways [img]smileys/smiley16.gif[/img]
uncljohn
Nov 26, 2012 11:13 PM
Mera
Sep 1, 2007 09:37 AM
mike93z
Jul 20, 2007 04:54 PM
MengusDew
May 16, 2007 04:45 PM
jonni 95 SL2
Sep 13, 2005 04:18 PM
