93 sl1 idles high poor fuel milage
Old 11-09-2014, 09:30 AM
joma1993's Avatar
Default 93 sl1 idles high poor fuel milage
Exactly what title says, just bought the car, only fueled up twice and got 25 and 27 mog respectively, I do mostly country driving and would expect it to be more like 35 mpg, as far as idling high, it idles about 1200 rpms even when warm
Old 11-09-2014, 12:26 PM
goaliemo's Avatar
Put a new fuel filter in, and run some fuel injection cleaner through.
Also change the spark plugs, wires, oil, oil filter.
Before you change the oil though, run some MMO through it for 20 minutes to help clean the stuff outta the motor.
Old 11-09-2014, 04:11 PM
That the classic symptoms for a leaking intake manifold gasket. It's easy to check, the weak spot in the intake is the upper outboard corner of the #1 cylinder, but leaks can occur anywhere. Spray something, like WD40 or carburetor cleaner around this area and see if the idle is affected in any way. If there is a leak, there will be some effect on the idle.
You could also have a vacuum leak somewhere else, like a vacuum line, but the manifold gasket is the #1 culprit.
Old 11-15-2014, 07:07 PM
I agree with Keith. And FYI in case you don't know, the MMO that Billy is referring to is Marvel Mystery Oil. You can get it at Walmart and most of the chain auto parts stores.
Old 11-16-2014, 12:36 AM
Surprised no one mentioned replacing the ects w r t gas mileage. There's a sticky about it on the site. Get parts from a gm dealer.
Old 11-16-2014, 10:52 AM
Good answer too, I guess that's why you're here.
Old 11-16-2014, 07:12 PM
i like to think I serve some purpose around here.
Thank you for the validation
Old 11-17-2014, 05:25 AM
joma1993's Avatar
Where do I find the sticky?
Old 11-17-2014, 06:01 PM
https://www.saturnforum.com/forum/general-tech-help-13/etcs-its-connnector-6417/ in the general tech section. The ECTS when it fails usually makes your car run way rich, eating up gas and killing the fuel mileage.
It's a 2 wire sensor sticking out of the head on the driver's side. The connector is a squeeze connector. Swap out when car is cool.
Old 11-17-2014, 10:30 PM
Check that connector and make sure it isn't cracked. I replaced the sensor needlessy in one of mine only to discover it was the connector that was defective. I'd already purchased a new one along with the sensor, but the sensor was just money I could have saved. I put it in anyway and gave to other one to a former member.
drivewayguy
01-06-2014 11:04 AM
dirtybart
04-29-2010 01:12 PM
tommy7133
05-01-2008 11:44 AM
sgm81
12-21-2006 09:48 PM
paulorlo
02-01-2006 02:29 AM
Quick Reply: 93 sl1 idles high poor fuel milage
