Key stuck in iginition and won't turn
Old 07-28-2009, 08:50 PM
geeve420's Avatar
Unhappy Key stuck in iginition and won't turn
I have a 97 sl2 and the key is stuck in the ignition and I can't turn it at all. I have taken the colum apart and tried to pop the cylinder, but I can't get it into ACC to pop it. I have tried making sure it was park, I have tried turning the wheel and key. I am at a total loss . any help would be greatly appritiated
Geeve
Old 07-29-2009, 02:02 PM
jlannigan's Avatar
I had something similar in my 97 sl2, i just had to keep bouncing it around until i could get it to acc, other than that, you have to take it to a dealership. Was the decay of the ignition switch a slow decent or did it all of a sudden just go bad?
Jay.
Old 07-29-2009, 03:32 PM
geeve420's Avatar
Thanks for the reply. What do you mean "bouncing it around"? It was just all of a sudden. Had no issue with it prior. I was driving to work and the alternater gave out so I pulled over. My father inlaw came and put it on a trailer (was able to start it enough to drive it on). he got it home and now the key is stuck completely. I'm about to scream cause we are borrowing a car in the mean time and it sucks Any ideas? I really don't want to take it to the dealer cause I'm sure it'll cost more than the car is worth.
Geeve
Old 07-29-2009, 07:19 PM
Atlaswar's Avatar
This is as close as I could find to your problem
Ignition Key May Not Rotate in the Ignition Cylinder and/or Steering Wheel May Lock with the Key in Ignition Cylinder in the LOCK Position #97-T-43 - (Jan 10, 2003)
The Ignition Key May Not Rotate in the Ignition Cylinder and/or Steering Wheel May Lock with the Key in the Ignition Cylinder in the LOCK Position -- Replace with a New Ignition Cylinder Unit
1997 Saturns built with a second design key
Condition:
After the ignition key has been turned to the ACC, RUN or START position, and rotated back to the LOCK position, the ignition key may not rotate unless it is removed from the ignition cylinder and re-inserted into the ignition cylinder.
Also, the steering wheel may lock with the ignition key still in the ignition cylinder, with the ignition cylinder in the LOCK position. The steering wheel should lock only after the ignition key has been removed from the ignition cylinder.
Cause:
A loose interface between the key minder actuator in the ignition cylinder and the ignition cylinder housing.
Correction:
Replace the ignition cylinder unit with a new ignition cylinder unit P/N 21170896.
Old 07-29-2009, 08:16 PM
well dang, my 97 SC2 cylinder always needs the key pulled out and put back in after turning it off -- think it's been that way from the start....
12 years worth hasn't yet killed it -- guess I'll wait till it is totally hosed
Old 07-29-2009, 09:03 PM
geeve420's Avatar
Well we got it. For those with the same problem we did this.......Disconnect Battery, pulled fuses for the airbag,Took the four bots out of steering column housing so it splits in two and the cylinder is exposed. There is a lock nipple on the gauge side of the cylinder, you take a flat head screwdriver and a BFH (Big Fu%^ing Hammer) and beat the crap out of it while saying things you will repent for later. As you do this wiggle the key and turn it till the cylinder releases the key.
Once we got the key out I took my handy wallet key and compared them.....I guess you could say 12 years had worn the key almost completly smooth. With that out of way we moved on to the tension pulley (what I thought was an alternator problem), and that my friends is a whole other story.
Thank you all for your input and I hope this helps someone else.
Geeve
Old 07-30-2009, 11:12 AM
jlannigan's Avatar
Congrats on getting it fixed
Old 07-30-2009, 10:31 PM
bookmarked for when mine goes to crap........
Old 07-30-2009, 11:13 PM
MR.SC2's Avatar
geeve, are you sure the steering wheel isnt locked? lol, broke a key in my old ford that way
Old 07-31-2009, 06:48 AM
geeve420's Avatar
Yeah it wasn't locked. I could move the steering wheel all the way left or right. I could also hear it pass by the lock. It was basically the key was so worn out, that he cylinder didn't want to let go.
Quick Reply: Key stuck in iginition and won't turn
