blinking ses light
Old 04-13-2014, 09:37 AM
That's the truth
Old 04-13-2014, 07:06 PM
How much oil does the car use?
Old 04-14-2014, 08:59 AM
roc2325's Avatar
I would say about every two weeks I'll have to add 3 quarts of oil or so
Old 04-14-2014, 04:19 PM
3 quarts in two weeks? Man, you must have a leak or be putting out one hell of a smoke screen. That's a lot of oil, depending on how many miles you're talking about. Even with a lot of miles, that's too much oil. You either have some bad valve seals, guides or busted rings.
Old 04-15-2014, 07:24 AM
I think then you have just come up with a reason for a blinking SES light due to miss-fireing.
With that kind of oil consumption fouling the spark plugs is a very real possibility.
The sensing for misfires while clever when the car was new it still had a problem or two one of which it is prone to failure depending on the type of spark plug used. For example the newer platinum plugs with a different shape configuration of the tip vs the regular NON-platinum plug causes a false misfire. And error code.
With that kind of oil consumption fouling plugs could cause a real misfire or you might be using platinum plugs, dunno. I don't think you mentioned it. An engine that worn out could have any number of problems due to excessive oil consumption.
You have changed a lot of parts through shot-gun trouble shooting. When the real problem might very well be.
Excessive oil consumption
or
the wrong spark plugs being used.
Old 04-15-2014, 10:26 PM
so what kinda plugs are you using
Old 04-15-2014, 10:31 PM
roc2325's Avatar
I actually just did the pugs and wires I used a ngk but I don't remember which kind what's the best alligator these cars also the actually does use that much oil I would say closer to every month 2 or 3 quarts
Old 04-16-2014, 01:08 PM
pull the plugs and see if they are oil fouled
Old 04-17-2014, 11:10 AM
roc2325's Avatar
Ok I'll pull them and see what they look like
kspomerantz
04-20-2011 09:57 PM
ecd777
04-19-2011 10:22 PM
volfan945
05-02-2010 07:58 PM
KCKIM
12-28-2008 08:18 PM
raw213
03-17-2008 08:07 PM
Quick Reply: blinking ses light
