need help
https://www.saturnforum.com/forum/sh...ighlight=codes
Well GOLLY -- the post wasn't mine -- it belongs to the revered OceanArcher
Just knew it was out there Rube. Some people need to see the same thing in more than one form to fully understand it.
That and you're fun to mess with
need help
what is an ects and where is it
Engine Coolant Temperature Sensor. Used to measure coolant temp and sends info back to the PCM. Influences many things including air/fuel mix.
Being a 95, yours has two coolant temp sensors a single wire sensor thart drives the dash gauge and a 2 wire device that is used by the PCM. You want the TWO wire sensor. It is sticking out of the driver's side of the cylinder head.
Connector is a squeeze connector.
Sensor is threaded into the head. If you find a resin tipped one it will likely be cracked. Regardless, replace with an OEM sourced two wire ECTS and connector sourced from a GM dealer. $40 altogether and connector is dealer only part. Even minor corrosion on connector wreaks havoc on reading.
damn. that's a long trip for those bits.
I guess a car with no exhaust path would be a problem
Glad you got it running.
Just another example of how the forum experience can guide, but without being there to hear, touch , and play with, we can only be so helpful.
Thanks for taking the time to come back and post the resolution. It may help others in the future.
