Reply
Old 06-06-2012, 07:56 AM
OceanArcher OceanArcher is offline
OK -- From your description, I would hazard this comment ... since you found no shorts to ground in your meter test of the wiring, and the fuses did not blow when the connectors were unplugged, the PCM is at fault. You kinda proved that by plugging the PCM back into the system, and blew fuses again.
Then, you put in a larger fuse and tried it, and blew that one too. (something that I would not have tried, but it's your car, your decision...)
Now, the fuses no longer blow out, but the engine still will not start. I'm of the opinion that the PCM needs to be replaced, but I'll listen to other thoughts/comments ....
__________________
Mike -- MS Gulf Coast
'93 SW2 -- dark blue
'02 L200 -- gold
'09 Aura XE -- burnished gold
Old 06-06-2012, 09:53 AM
derf derf is offline
I like OldNuc -- he's a knowledgeable straight shooter.
Is there any corrosion on the pcm connectors or plugs that might be causing an intermittent short to another terminal or an intermittent connection? I'd think you'd have noticed while tracing but feel compelled to ask.
Usually when solid state circuits fry internally they stay that way --- if the internals for the PCM B circuit fried to ground, I'd expect them to stay that way.
I also wouldn't expect another batt feed to the PCM to fry out in the midst of testing
nor would I expect both circuits to suddenly be OK(not frying fuses) -- unless the pcm internals at the terminals both fried so extensively they are now both open circuit.
Are you still getting 12V at the pcm harnesses for PCM A and PCM B?
You might want to poke around at some sensors with key on (like the coolant temp sensor) to see if they're getting any juice, and also see if the diag port is functional--- if your PCM is toasted I'd expect a whole lot to be not working if you've killed all power to your PCM
__________________
On an ordinary day
Not in an ordinary way
All at once the song I heard
No longer would it play
For anybody
Or anyone
That needed comfort from somebody
Needed comfort from someone
Who cared
To be
Not like you
And unlike me
___________________
derf/Wash PA
95 SC2 ~232K
97 SC2 ~244K
'14 Ford Escape SE 2.0L ~9k
Old 06-06-2012, 09:56 AM
jspd234 jspd234 is offline
what do you think about it possibly being the crank positioning sensor?
Old 06-06-2012, 10:01 AM
no corrosion anywhere at uhjb.
and yeah, i thought it was odd to have pcm 1 fuse to fry as well.
i will check today to see if i still have 12v to the pcm.
.......to be continued.......
Old 06-06-2012, 10:07 AM
Defective CPS will indeed inhibit spark if faulty, but if pcm is hosed, any CPS signal (good or bad) would never get interpreted correctly.
Or are you asking could a shorted CPS cause all of this?
I don't really don't think so but it's easy enough to throw your ohmmeter across to calm your mind....
__________________
On an ordinary day
For anybody
Or anyone
Who cared
To be
Not like you
And unlike me
___________________
derf/Wash PA
95 SC2 ~232K
97 SC2 ~244K
Old 06-06-2012, 07:30 PM
plugged in a cheap actron scanner and a super deluxe high zoot zillion dollar napa genesis scanner and both say no communication with car. the mechanic who owns these scanners says its probably the pcm fryed......lkq will sell me one for $100 with a 6 month warranty. hmm......
Old 06-06-2012, 09:16 PM
There are some for sale here:
http://www.ebay.com/sch/i.html?_saca...999+Saturn+pcm
the used ones are under $100 and the remans closer to $200.
Personally I prefer the OEM used ones pulled from wrecks/junkers cause you know at one time it actually was functional in an S car.
Need to be sure the part numbers match.
Also I believe it will need to be reprogrammed at a GM dealership with the appropriate programming tool.
I'd actually find the part number off the existing PCM, then call a GM dealer (preferably one that used to service Saturns) and ask them to look up acceptable part numbers that can serve as replacements.
__________________
On an ordinary day
For anybody
Or anyone
Who cared
To be
Not like you
And unlike me
___________________
derf/Wash PA
95 SC2 ~232K
97 SC2 ~244K
Old 06-07-2012, 12:48 PM
open door, dome light goes on. i put key in, it chimes. turn ignition on, lights on dash go on. stereo works, hvac fan turns on. everything works like it should. i will check power and ground to obd II port next per your instructions....
Old 06-07-2012, 04:47 PM
I believe all of the circuits you mentioned (except the ODBII) are fused separately and do not rely on the PCM for power -- so it is should not be unexpected that all that stuff works but the diag port does not.....
__________________
On an ordinary day
For anybody
Or anyone
Who cared
To be
Not like you
And unlike me
___________________
derf/Wash PA
95 SC2 ~232K
97 SC2 ~244K
Old 06-08-2012, 01:09 PM
body fuse is good. checked power at obd port. orange is 12v, i am almost ready to order another pcm on ebay....50 bucks....
Reply
Tags
05, 10, 115v, 2005, 2008, blown, burnt, fuse, location, obdii, outlook, pcm, pcmb, port, relay, replacing, saturn, vue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Auto Parts
- Exhaust
- Bike Carriers
- Car Vacuums
- Hidden Hitch
- Hitch Covers
- Dash Kits
