Power locks quit working - Saturn Forum - Saturn Enthusiasts Forums
Reply
LinkBack Thread Tools Search this Thread
Old 09-04-2008, 02:39 PM
My 2004 Saturn Vue''s power locks just quit working. The car didn''t unlock when I put it in park and it won''t lock when I put it in gear. The power lock inside the car and the remote won''t work either. I hear clicking from the relays, but that''s about it. Any ideas? Thanks
Old 09-04-2008, 02:53 PM
Unless I''m mistaken (highly possible), placing your vehicle in park will not cause your doorlocks to release - you have to shut the engine down, and remove the key (unless you unlock them manually with the button).
Since your doors will neither lock nor unlock, my first place to look would be the fuse panels ... good luck.
Old 09-04-2008, 06:14 PM
It does unlock when I put it in park, and locks when put in gear, or at least
use to. I found a blown fuse and replaced it several time and they just keep
blowing. I didn''t find it before because it was listed under relays in the
book. I may have to just take it in.
Old 09-04-2008, 07:52 PM
Sounds like the best thing to do man.
Old 09-05-2008, 04:25 PM
Pester
Sounds like a shorted wire, or possibly a shorted actuator, especially if you keep on blowing fuses. Speaking of fuses, check your manual, and make sure that the fuse is the correct rating for the circuit DO NOT PUT AN OVERSIZE FUSE IN THE CIRCUIT FIRE HAZARD!!
Reply
Thread Thread Starter Forum Replies Last Post
Power locks not working DailyPlanet Saturn S Series Sedan 5 06-29-2014 08:24 PM
SC2 Power door locks popping unlocked after locking derf Saturn 3 Door Coupes 7 09-27-2012 10:40 PM
front lights quit working bradfrog Saturn S Series Sedan 4 11-20-2010 01:37 PM
Odometer quit GRETSCH43 Saturn S Series Sedan 1 06-10-2009 03:57 PM
99 SL2 Power Locks gone crazy.. imaukfan General Tech Help 5 01-04-2008 05:33 PM
Tags
automatic, blowing, car, electric, fuse, fuze, lock, locks, power, saturn, unlock, vue, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
