2002 Saturn Vue
Old 12-19-2014, 04:07 PM
gattabout's Avatar
Default 2002 Saturn Vue
Swapped out VTI all wheel drive to a 5 speed front wheel drive.
Plugged selector switch from auto trans in to read park hoping to start fuel pump and starter. Everything works, except fuel puimp and starter. I'm missing something?
Gattabout
Old 12-19-2014, 04:09 PM
gattabout's Avatar
I have all the shop manuals for 2002 (Ebay). Looking for solution.
Gattaboiut
Old 12-20-2014, 07:54 AM
Maybe you need to run the power to the switch on your clutch instead of neutral safety switch? I don't know, just guessing.
Old 12-20-2014, 08:26 AM
blaisa's Avatar
Gattabout
Are you using an engine wiring harness from a manual equipped Vue? If not then know that they are wired different. You will need to use a Manual Vue wiring harness and manual vue ECM. Remove automatic transmission and old ECM from the engine because they will no longer work for the Manual transmission application.
The clutch pedal which you had to install has a switch on it. Cut the small wire going to the starter a little way away from the starter and splice into each side of that with wire long enough to run to that switch. This will provide you with a neutral safety switch.
Old 12-21-2014, 09:22 AM
gattabout's Avatar
Default 2002 Vue tranny swap
Using 5 speed wiring harness and ECM. I have a security light on the dash which is on. Could this need cleared for fuel system to work? Need to know how?
Thanks, Gattabout
Old 12-22-2014, 09:55 AM
blaisa's Avatar
ECM needs to be taught to recognize the vehicle. If you need to know how let me know.
Andy
Dance83
03-12-2013 07:50 AM
scanlon
01-09-2011 07:42 AM
tnsurveyor
04-13-2008 06:31 PM
Vue81
07-10-2007 10:33 PM
U_turn
08-27-2005 05:14 AM
Quick Reply: 2002 Saturn Vue
