What type oil in Manual Transmission Sl1 DOCH
  #31
Old 08-12-2015, 02:58 AM
Koster2's Avatar
Hello Derf!
1)Do you happen to know the exact dimensions of the glass hatch. And I suspect that is not the native window.
2) You do not know whether there are cars like you and me, only in the configuration without air conditioning? I want it all off and put a short strap that would not cool the compressor in vain.
  #32
Old 08-12-2015, 03:34 AM
1) By glass hatch, do you mean sunroof = window in top of car?
2) I think A/C was an option on the SL1 SOHC, but standard equipment on the SL2 and SC2 (can't remember). People modifying for performance would take off the Power steering pump and the A/C compressor -- there's a belt for that because this was the configuration of the base model SL. But A/C delete only? Don't know.
But everything is out there on the internet........
  #33
Old 08-12-2015, 03:52 AM
Koster2's Avatar
Yes, yes) Sunroof)
  #34
Old 08-12-2015, 11:45 AM
No I do not know the dimensions but it should be GM part # 21051019. (1992-1996)
  #35
Old 08-13-2015, 08:44 AM
Koster2's Avatar
Thank you! It may also be useful to me.
  #36
Old 08-30-2015, 01:19 PM
Koster2's Avatar
Hello Derf! Is it possible to put the front disc brake on the rear wheel? If you drill a hole, he will go. But I'm not sure whether to run the cylinder itself.
  #37
Old 08-30-2015, 06:27 PM
19bonestock88's Avatar
You're talking about a rear disc conversion? Or is your car already rear disc?
  #38
Old 08-30-2015, 06:47 PM
Koster2's Avatar
I have another car- donor. I want to take off her front brakes and rear drum put in place. I practiced there someone like that?
  #39
Old 08-30-2015, 09:30 PM
The correct way to convert a 2 wheel disc/2 wheel drum vehicle is to a 4 wheel disc brake vehicle is to remove the drum related hardware and replace it with the REAR disc brakes from a donor SL2, SW2, or SC2.
Trying to put front brakes on the rear is not a good idea. The braking behavior would be strange, the rotor sizes and pad sizes are different, the caliper size is different.
Many people have done the drum to disc rear conversion. Let me go find a few links and I will post them for you.
And please, when you are posting questions , please say "hello" to the entire forum---not just me....many others are happy to help!
  #40
Old 08-30-2015, 10:15 PM
Also, the front rotors are vented, the rear are solid.
As you read these, pay special attention to Posts by Low Saturn and Wolfman. They know what they are talking about.
Also, the emergency cable length is different for rear drums vs rear discs, so you will have to sort out which ones from which years you can use on your car.
Links to SL1 SC1 SW1 Rear Disc Brake Conversion
Rear Disc Brake Conversion - Saturn Spot
Rear Disk Brake Conversion SL1 - SaturnFans.com Forums
Rear disk conversion on 2000 SC1 - SaturnFans.com Forums
Check list for rear disk brake conversion - SaturnFans.com Forums
Quick Reply: What type oil in Manual Transmission Sl1 DOCH
