SL2 Cut off while Driving
Old 11-27-2016, 01:45 PM
Impala1960's Avatar
Default SL2 Cut off while Driving
1998 Saturn SL2 cut off while driving, would not restart. You can hear a relay clicking in the fuse box but not a sound at the starter. Replaced relay still no start. Engine will not turn over Any ideas of where to go from here. Thanks for any help I can get.
Old 11-27-2016, 07:56 PM
I would see if you can turn the engine over by hand, with a wrench on the crank bolt.
Old 11-28-2016, 05:40 AM
I agree with Andy. But the first thing you should do is check and make sure you have oil in the crank case. If you have oil and can turn it by hand, try tapping the starter with a hammer. The bendix might be hanging up on it, if it's a high mileage car with the original starter.
Old 11-28-2016, 01:03 PM
That clicking is the fuel pump relay closing to prime the fuel system, then opening.
So you have at least some current flowing from the battery (meaning only that the battery is still connected.
By all means check your oil and let us know where it is on the dipstick.
Did the OIL dash light come on at any point before it shut off?
jcoll72305
01-24-2013 09:45 AM
skitzo88
08-06-2011 11:42 PM
Junie
08-02-2010 05:09 PM
derin6770
07-08-2010 05:41 PM
cadman33619
06-16-2009 05:46 AM
Quick Reply: SL2 Cut off while Driving
