piston rings and head gasket - Saturn Forum - Saturn Enthusiasts Forums
Reply
Thread Tools Search this Thread
Old 01-20-2005, 08:34 AM
can i pull the pistons threw the head by dropping the oil pan or do i really have to pull the moter out? open for ideas
Old 02-18-2005, 07:10 PM
You dont have to pull the motor out, but it would make it much easier just having it out and not having to lend on to the front of your car. You can take the head off and and the oil pan. Loose the Pistons and pull them from the top of the block and make sure you bore the piston holes and get new bearings.
Old 02-18-2005, 11:24 PM
i sold the car the thing is you cant u must pull the motor. the timing chain cover is in ur way and so is the crank pully you also have the flywheel. there is 5/18 bolts you cant get to. thanks for the info though
Old 03-17-2005, 08:57 PM
Quote:
I would figure an ASE certified "Master mechanic" would know a simple question like that. Or at least someone who owns 3 shops and builds 11.1 second Civics and 7 second T/A's.
Old 03-18-2005, 01:18 AM
i did but there are always short cuts, and guess what there would have been but there was 3 flywheel fex plate bolts that wouldnt let me do that besides you need to pull the trans and the engine as a hole. BET YOU DIDNT KNOW THAT but hey ase people still ask questions and read books. any good tech could tell you that!
Old 03-18-2005, 03:32 AM
Actually, I did know that.It's funny what you can learn from a Chiltons manual. But your not just an ASE certified mechanic. You a certified "Master" mechanic.
Old 03-18-2005, 06:17 AM
Yes, you should be able to pull the pistons through the head by removing the oil pan. Piece of cake, really [img]smileys/smiley1.gif[/img]
Best time for all of this would be during an oil change, you're down by the oil pan anyways [img]smileys/smiley16.gif[/img]
Reply
Thread Thread Starter Forum Replies Last Post
The door bell rings and there stands uncljohn Off Topic 3 11-27-2012 12:13 AM
Bad head gasket on a 95SL2, what to do??? Mera Saturn S Series Sedan 3 09-01-2007 10:37 AM
pistons needed mike93z Private 'Wanted' Classifieds 2 07-20-2007 05:54 PM
Finding a pistons set MengusDew Saturn S Series Sedan 4 05-16-2007 05:45 PM
new rings and head gasket jonni 95 SL2 General Tech Help 4 09-13-2005 05:18 PM
Tags
2005, change, diffculty, gasket, head, heads, motor, piston, pull, ring, rings, saturn, saturtn, sl2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
