Location of MAP sensor on 2000 SW2?
Old 06-15-2010, 06:00 PM
JonWSW2's Avatar
Default Location of MAP sensor on 2000 SW2?
My "service engine soon" light is on and the parts store scanned it and said it was a MAP sensor code. I have the Haynes DIY manual but it doesn't give any information on where this sensor is located and how to R/R it. Any help?
Old 06-18-2010, 01:19 PM
I assume it is in the same place as on the older DOHC models -- at the top of the far end of the throttle body.
Make sure you don't lose the little plastic sleeve that is around the sensor port when you pull it -- you'll need to reuse it,
Old 06-30-2010, 12:01 PM
JonWSW2's Avatar
Turns out it is in a different place - it is under the Throttle Position sensor on the intake manifold just beneath the throttle body (left side of car). I replaced it (it snaps out and in) and disconnected the battery for a few minutes. The light didn't go out, so this morning when I got the oil changed, I had them read the codes again and reset them with their scanner. So far the light hasn't come on again, I'll keep my fingers crossed.
Old 07-03-2010, 03:10 PM
that makes me wrong -- but better informed
Old 07-04-2010, 09:37 AM
JonWSW2's Avatar
Looks like the old MAP sensor was indeed bad - the light has never come back on again.
Old 07-04-2010, 09:17 PM
glad to hear
Old 07-04-2010, 09:50 PM
Congrats on the repair ............
sep25
07-24-2011 10:56 AM
E04677
01-14-2010 08:07 AM
PdPuNOme
10-21-2009 09:07 PM
thatsreality
04-09-2007 03:43 AM
I3eXa
04-05-2007 02:56 PM
Quick Reply: Location of MAP sensor on 2000 SW2?
