codes
Old 08-01-2006, 05:11 AM
henrylford's Avatar
how do you get thecodes on a saturn i have a 1994 sl1 and i do not have the money to buy the tool to get the codes that way so is there a way do do the like you can on dodges and chevys
Old 08-12-2006, 10:13 AM
lgrzybek's Avatar
According to the Haynes repair manual:
Jump terminals B and A 0n the ALDL (Assembly Line Data Link), which is
located under the driver's side dashboard, near the kick panel.
The ignition should be on, but the engine should not be running.
The unit will flash Code 12 three times and then it will flash any stored trouble codes.
To clear the codes from memory, pull the battery cable for 10 seconds.
Haynes #87010 has a complete listing of the codes.
Lou
z4me95
09-25-2006 10:15 PM
calmb4dastorm
07-07-2006 12:11 AM
Turbochump
06-07-2006 04:28 PM
mikes 1994 z28
03-27-2006 04:47 PM
bam_bam1ca
11-15-2005 12:08 AM
Quick Reply: codes
