1996 saturn sl sluggish starting out
Old 07-13-2011, 01:33 PM
margorita03's Avatar
Default 1996 saturn sl sluggish starting out
I have a 1996 saturn sl have always had issues with this car leaking trannyfluid bad seals I suppose just yesterday when starting out from drive car is not responding very well sluggish then after car shifts itself seems to be fine it has always had a bump when palced into reverse looking for any suggestions on what this could be or what we should try?
Old 07-13-2011, 02:40 PM
I am guessing it is and automatic ? Is it to the full mark on the dipstick?
When was the fluid and filter last changed?
Old 07-13-2011, 02:55 PM
I wouldnt even guess to know we are constantly putting in tranmission fluid and have never changed the filter could that be a problem as far as it not acclerating? and yes the dipstick now reads full
Old 07-13-2011, 04:03 PM
Change the filter, even if that is not it, there is one less thing .
Old 07-13-2011, 04:23 PM
Yes - the filter should be changed every 30,000 miles
Old 07-13-2011, 04:38 PM
It solved my problem of "slamming"into reverse.
Old 07-13-2011, 04:40 PM
then get the oil leak "diagnoised" it might be a simple and inexpensive repair.
you really need to know what is leaking.
Old 07-13-2011, 04:55 PM
I know its the seals when it was inspected last month at my garage they told me I would have to get it done I was just realy concerned when i started in drive that it has about half the power it usually does will definatley make my hubby do that this evening looks like a pretty easy thing to do much easier then replacing that waterpump last month
Old 07-13-2011, 05:39 PM
Oooo A water pump is for small hands for sure.
Old 07-13-2011, 05:42 PM
I'm not sure what replacing tha water pump has to do with anything in this thread other than to bitch about how hard it is to change when you have no idea what your doing. The S-Car water pump is not a tough job and much much easier to replace then alot of cars on the road.
Is that a blue jet?
Quick Reply: 1996 saturn sl sluggish starting out
