Power Steering
Old 10-02-2008, 04:27 PM
97SL2's Avatar
I have a 97 SL2 and the power stering pump and rack need to be replaced. Have any of you performed this job, and if so how hard was it? Thanks
Old 10-06-2008, 09:40 AM
Low Saturn's Avatar
Yes, I''ve done this. Took me 45 minutes. But I work on Saturns a lot. Once you get the parts, its should just take an afternoon.
Old 10-06-2008, 10:36 PM
97SL2's Avatar
It only took 45 min for the pump and the rack? I hope I can do it on a day then.
Thanks
Old 10-07-2008, 12:39 PM
Low Saturn's Avatar
To get the pump out easier, support the engine from below with a jack. Then remove the upper engine mount and remove the two lower engine mount to cradle nuts. Then jack up the engine as far as it will go to get access to the pump mounting bolts.Edited by: Low Saturn
JEKoenig0524
02-22-2015 06:43 PM
dbhost
12-06-2011 04:03 PM
saturne20
08-01-2008 10:14 AM
alunga
09-18-2006 11:37 PM
lynn
Saturn L300
09-12-2006 02:10 PM
Quick Reply: Power Steering
