2003 lw200 has slight miss during idle
Old 06-24-2015, 10:13 PM
Jobolt's Avatar
Default 2003 lw200 has slight miss during idle
Car has 134000 miles and has started to have a slight miss during idle, like a slight miss or a hickup at random. Car runs fine otherwise. While in gear stopped it would skip or miss at random, take it out of gear and place it in N and appear to go away. Same results with or without running the A/C
Replaced the four plugs with autolites. replaced the rubber boots around the plugs, removed the throttle body and cleaned inside etc, cleaned at air filter, added fuel injector cleaner to the gas, and still misses at idle at random.
Any ideas would be helpful
Cheers
Old 06-30-2015, 03:22 PM
goaliemo's Avatar
Please stop by the New Member section to introduce yourself.
From there, we will inform you of the rest of the rules to this forum.
Are you sure the plugs are tight enough? I know that is a common issue with misfire codes popping up during idle.
Old 06-30-2015, 11:33 PM
Plugs should be just past hand tight---I call it snug.
Aluminum so too much torque =unhappy situation.
Any codes?
Usually misfires get picked up like nobody's business and the PCM throws codes.
Were the plugs you removed oil soaked or fuel soaked?
If the crank posit sensor (CKP) was acting up, your car would likely not run at all. No signal from CKP = no spark + no fuel= no run. Or throw a code (rare)
Remember that the idle speed in neutral is different than the idle speed in gear, which is lower. So it may have to do with something other than the traditional ignition system.
I could throw out wild guesses all night, but that does neither of us any good.
Keep on with the fuel injector cleaner while we troubleshoot.
Sorry for taking so long to respond.
You'll be granted a few extra days past the traditional 10 day limit due to our ineptitude.
Old 07-04-2015, 01:13 PM
If none of those suggestions work, try cleaning the throttle body.
Old 07-05-2015, 12:09 AM
he already did.
WELCOME BACK, RUBE!
Old 07-05-2015, 07:17 AM
Yeah, my bad derf. I see the throttle body was removed and cleaned. Duhhhh. Maybe a slight vacuum leak?
Old 07-13-2015, 04:11 PM
scoffman's Avatar
It probably wouldn't hurt to change the fuel filter too. I it's getting fuel since it's a slight miss at idle, but if the filter hasn't been replaced in a while it needs it. Is the SES light on? any trouble codes?
Old 07-14-2015, 01:26 AM
the dude is banned for lack of activity -- which includes never coming back to say yay, nay, nor thank you
Thread closed
Rubehayseed
10-05-2014 06:46 AM
steve needs help
08-04-2014 07:38 PM
4x4Jeep
03-07-2014 10:47 PM
Saturntuner88
08-01-2009 05:11 AM
mattiemo
02-23-2008 09:19 AM
Quick Reply: 2003 lw200 has slight miss during idle
